No. That switch panel is not just a thin cover. It is the entire switch assembly.
Thank you for the quick response Ron
Having not seen that panel removed, I’m guessing by your response that there isnt a way to drill from the bottom side (carefully) and make it work?
I want the protection, but I want it to look a little more professional than what was described in this thread.
Any new ideas since 2002?
Dan,
One of my clients has a mixture guard. Titanium laser printed…
I am a fan.
Attached with adhesive. The screw holes were printed in place but not utilized.
The master switch protector hoop could be made the same.
Trying to bolt thru the panel would be tricky and not an owner item at all. Plenty to go wrong.
Jim Barker wrote the following post at 6 Jun 2018 13:39: Dan,
I am a fan.
LOVE this!
Jim Barker wrote the following post at Jun 6, 2018 17:39: Dan,
I am a fan.
via iCopa
That is pretty close to what I was working on with the drawer pull, except I was going to bolt it down instead of gluing it down… I’m off to menards to see what I can come up with.
I really like that. Thanks for posting it up.
Dan
