Hi there Brian,
There is a big difference between flying a non-precision approach in a regional jet, and in an SR-22.
Stabilized approaches are certainly a good thing. The concept is fairly ubiquitous in GA. When it comes to NP approaches in little aircraft, however, dive-and-drive is the way to go. Side note, you mentioned glideslopes in your post, but I think you were just referring to non-precision approaches. The dive-and-drive concept has no relevance on an ILS approach.
First, the cons. Depending on the aircraft, configuration and power settings are changing. The pilot may be re-trimming the aircraft during or after the “dive” and prior to the next. Verifying successful deployment of gear (if RG) and flaps also adds to the workload, although it should occur prior to the Final Approach Fix.
Do that with a 40,000 lb. airplane and your hands are full. Turbine engines take longer to spool up. Sweptwing airfoils and their various drag/lift producing devices, flown at low airspeeds, require a different type of piloting technique than what we’re accustomed to in General Aviation. And of course the greater inertia of a transport category turbojet airplane mean that configuration changes are a relatively big deal. A little late here, a second or two behind there… it can add up.
But, back to our little 3,400 lb’er. In the SR-22, the pilot workload increases only with respect to configuring and flying the aircraft. There are no Vref speeds to calculate. The inertia of the aircraft is quite low due to its relatively light weight. Piston engines respond quickly to increases in power demands. Dropping down from one altitude to another is just not a big deal. The fixed-gear configuration of the Cirrus makes it even easier. Flaps 50% prior to the FAF, trim it, and you’re done. Just pull out the power to go down.
So, initiating at 600-700fpm descent from one stepdown fix to another, on a typical approach under typical conditions, should be easily accomplished by the average instrument pilot. Why stabilize? A better question might be, why not stabilize?
The simple answer is, in most general aviation aircraft, we’re not equipped to easily take advantage of a calculated and stabilized descent rate which brings us to the VDP, or some point prior to the VDP, on a NP approach. (It goes without saying that calcuating a descent rate which brings the aircraft to the Minimum Descent Altitude while simultaneously reaching the Missed Approach Point wouldn’t work - we need to be able to meet the requirements of 91.175(c)(1), which states that descent below MDA may only occur if “The aircraft is continuously in a position from which a descent to a landing on the intended runway can be made at a normal rate of descent using normal maneuvers,” among other requirements.)
When we use a stabilized descent rate across multiple stepdown fixes on a NP approach in small aircraft, we run the risk of running high and fast on the approach, and we may tend to minimize the time spent at MDA looking for the airport. If an anxious pilot spots the airport just as he reaches the MAP, he may feel pressure to chop the power and slam dunk the landing onto the runway, which could lead to a less-than-desirable outcome. I advocate descending to MDA as soon as the IAP allows - why deny yourself the opportunity to break out, find the airport, and start decelerating as soon as able?
I also believe that calculating and then maintaining a stabilized descent rate with accuracy is difficult in small aircraft. Our lower inertia - a good thing for making rapid attitude or altitude adjustments - also means that we’ll face more harassment from changing winds on the approach. When’s the last time you flew an approach with a truly constant groundspeed, from FAF to MDA? I can’t remember one - probably because I’ve never maintained a perfectly constant groundspeed on an approach. In short, I believe flying a faux glideslope taxes the GA pilot more than diving and driving down to MDA. I also believe the opportunity for errors of the worst magnitude are more likely when stabilizing a NP approach descent due to pilot fixation on factors not pertinent to safety. Just break out and give yourself more time to find the airport.
Best,
-Ryan
Scott:
I do not think it is the practice of the airlines to dive and drive. When you look at the string of planes on approach into BWI, arene’t they all on an extended profile descent from 10 or more miles out? Jerry gave the example of ORD which I think is an exception as their GS intercept altitude is 7000 feet. But take ANY large airport in the east here and I think you will see that all of the jet traffic is intercepting the GS above the GSIA only because they are lined up on the localizers so far out that they are already below the glideslope. In that position they are just flying below the glideslope to capture at a distance out furthur than what we typically do. In that configuration, it would not be the best approach to go lower when you are already below the glideslope.
