…and just like that I am breathing life into a 5 year old thread.
I am a student now doing my solo cross-country work, and I have had multiple 3’fers and 4’fers to get the SR-20 to spark up. I’ll try this tomorrow.
Can anyone explain what happened yesterday to me, though?
I flew from KSFB-KOCF-KCTY-KGNV for a full stop. Nice flight, no problems. I gassed up, ate and preflighted to head back home the same way (45 min on the ground.) I went through a normal pre-flight check list and set up for a hot start. First try- 15 seconds and no joy. No surprise, it’s a hot start. Second try, 10 seconds and I got a little kick- so I added a bit of throttle… it started to catch then died. No problem, I’ve been here before. 3rd try- no movement on the prop. “Well S**T!” Just a humming sound (as in when the battery is dead in your car.) I’m a hell of a hike from home and start groaning. The volts were good, and I got a slight drop when I turned the key again, but no movement on the prop.
So, I called my school who got me on the horn with a very seasoned mechanic. He has me turn the mags off and go rock the prop. Not a hand-start, mind you, just up and down until I can hear a “squishing” sound. He then directs me to get back in the plane and try to start just as normal.
I hop back in and “poof” I get two more no-joy start attempts, but the prop is moving. On the third try, I turn the key and we’re back to just a hum with no prop movement.
I rock the prop again, this time I get back in and get about 5 revolutions on the prop before it stops turning while I am still turning the key.
One more time rocking the prop, but this time no prop turn with the key. They send a mechanic out with a new starter motor and another SR-20 for me to take back to KSFB.
He says it sounds like the starter is shot, we talk, I gas up my replacement and when I come back out to pre-flight after signing for the Avgas, he’s got the original plane running.
What the Hell?
When I got back to KSFB, he said it started right up for him. He even said he got it to start 5-6 more times with no problems once back at KSFB.
Now look… I AM a newbie, but I can’t see what I might have done wrong here. I mean I turn the key, the starter turns the prop… that’s the deal. I told the mechanic, who had a very distinct “you poor dumb bastard” look in his eyes that if that plane doesn’t do the same thing to someone else within 2 weeks, I’ll buy the beer.
Any idea on this?
